SQLite Database not Opening on Android
New to Moai? Get started here with our best tips and tutorials.
Postby sgeos » Mon Jul 09, 2012 2:55 am
My LuaSQL sample runs on OSX and iOS. FWIW, this sample should run on a vanilla installation of Moai. When I try to open an SQL database on the Android host, I get the following error:
unable to open database file
Do I need to do anything special to use SQLite databases on Android?
EDIT: It looks like the short answer is yes. What does a person need to do to get a SQLite database to work on Android with Moai? Should there be some sort of an initialization call that moves the database to the correct location if the DB exists and the script is running on Android?
Any original code posted by me is released via the CC0 Public Domain Dedication. It is in the public domain. Do whatever you want with it.
sgeos
Re: SQLite Database not Opening on Android
Postby sgeos » Thu Jul 12, 2012 3:14 pm
In case anyone else runs into the same problem, this is what I wound up using.
  1. require "luasql"
  2.
  3. -- Database File Parameters
  4. dbname = "mydatabase.db"
  5. dbpath = "./"
  6.
  7. -- Special Handling for Android
  8. if "Android" == MOAIEnvironment.osBrand then
  9.   local systemdbpath = MOAIEnvironment.documentDirectory:gsub("/files", "/databases/")
  10.   if not MOAIFileSystem.checkFileExists(systemdbpath .. dbname) then
  11.     MOAIFileSystem.copy(dbpath .. dbname, systemdbpath .. dbname)
  12.   end
  13.   dbpath = systemdbpath
  14. end
  15.
  16. -- Create Environment and Connect to DB
  17. environment = assert ( luasql.sqlite3 () )
  18. connection  = assert ( environment:connect ( dbpath .. dbname ) )
  19.
  20. -- Queries Here
sgeos
Postby ibisum » Fri Jul 13, 2012 12:47 am
Great, thanks for sorting that out - exactly this problem was causing me a bit of trouble earlier this week on Android and now I know why.
Return to New Users
