I get:
doug@Iron:~/projects/moai-beta/xcode/osx$ ./build.sh
Building MoaiSample/moai/macosx for Debug
Build settings from command line:
CONFIGURATION_BUILD_DIR = /tmp/osx/default/MoaiSample/moai/macosx/Debug
SDKROOT = macosx10.7
=== BUILD NATIVE TARGET libmoai-osx OF PROJECT libmoai WITH CONFIGURATION Debug ===
Check dependencies
=== BUILD NATIVE TARGET libmoai-osx-3rdparty OF PROJECT libmoai WITH CONFIGURATION Debug ===
=== BUILD NATIVE TARGET libmoai-osx-luaext OF PROJECT libmoai WITH CONFIGURATION Debug ===
=== BUILD NATIVE TARGET libmoai-osx-untz OF PROJECT libmoai WITH CONFIGURATION Debug ===
Check dependencies
=== BUILD NATIVE TARGET libmoai-osx-zlcore OF PROJECT libmoai WITH CONFIGURATION Debug ===
Check dependencies
=== BUILD NATIVE TARGET moai OF PROJECT MoaiSample WITH CONFIGURATION Debug ===
Check dependencies
CompileC /Users/doug/Library/Developer/Xcode/DerivedData/project-enkuwmvinqocyegoauxtfevyrmlg/Build/Intermediates/MoaiSample.build/Debug/moai.build/Objects-normal/i386/FolderWatcher-mac.o ../../src/hosts/FolderWatcher-mac.mm normal i386 objective-c++ com.apple.compilers.llvmgcc42
cd /Users/doug/projects/moai-beta/xcode/osx
setenv LANG en_US.US-ASCII
/Developer/usr/bin/llvm-gcc-4.2 -x objective-c++ -arch i386 -fmessage-length=0 -pipe -Wno-trigraphs -fno-objc-exceptions -fpascal-strings -O0 -Wmissing-field-initializers -Wmissing-prototypes -Wreturn-type -Wnon-virtual-dtor -Woverloaded-virtual -Wparentheses -Wunused-function -Wunused-label -Wunused-parameter -Wunused-variable -Wunused-value -Wunknown-pragmas -Wshadow -Wsign-compare -Wconversion -Wshorten-64-to-32 -D_DEBUG -DDEBUG -DDEBUG_POSIX -DSQLITE_ENABLE_COLUMN_METADATA -DTIXML_USE_STL -DENABLE_CUSTOM_WEBVIEW -DHAVE_MEMMOVE -DXML_STATIC -DFT2_BUILD_LIBRARY -DDARWIN_NO_CARBON -DGLUTHOST_USE_LUAEXT -DGLUTHOST_USE_UNTZ -isysroot /Developer/SDKs/MacOSX10.7.sdk -fasm-blocks -mmacosx-version-min=10.7 -gdwarf-2 -fvisibility=hidden -fvisibility-inlines-hidden -I/Users/doug/Library/Developer/Xcode/DerivedData/project-enkuwmvinqocyegoauxtfevyrmlg/Build/Intermediates/MoaiSample.build/Debug/moai.build/moai.hmap -I/tmp/osx/default/MoaiSample/moai/macosx/Debug/include -I../../src/hosts -I../../src -I/Users/doug/Library/Developer/Xcode/DerivedData/project-enkuwmvinqocyegoauxtfevyrmlg/Build/Intermediates/MoaiSample.build/Debug/moai.build/DerivedSources/i386 -I/Users/doug/Library/Developer/Xcode/DerivedData/project-enkuwmvinqocyegoauxtfevyrmlg/Build/Intermediates/MoaiSample.build/Debug/moai.build/DerivedSources -Wall -F/tmp/osx/default/MoaiSample/moai/macosx/Debug -c /Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm -o /Users/doug/Library/Developer/Xcode/DerivedData/project-enkuwmvinqocyegoauxtfevyrmlg/Build/Intermediates/MoaiSample.build/Debug/moai.build/Objects-normal/i386/FolderWatcher-mac.o
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: In function 'void* FWWatchThreadMain(void*)':
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:154: error: '@autoreleasepool' was not declared in this scope
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:154: error: expected `;' before '{' token
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: In function 'void FWStart(const char*)':
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:188: error: '@autoreleasepool' was not declared in this scope
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:189: error: expected `;' before '{' token
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: In function 'void FWStop(const char*)':
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:215: error: '@autoreleasepool' was not declared in this scope
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:216: error: expected `;' before '{' token
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: In function 'void FWStopAll()':
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:229: error: '@autoreleasepool' was not declared in this scope
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:230: error: expected `;' before '{' token
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: In function 'char* FWEnumChangedFile()':
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:241: error: '@autoreleasepool' was not declared in this scope
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:242: error: expected `;' before '{' token
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm: At global scope:
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:100: warning: 'void FWUtilStartEventStream()' defined but not used
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:123: warning: 'void FWUtilStopEventStream()' defined but not used
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:165: warning: 'void FWLazyInit()' defined but not used
/Users/doug/projects/moai-beta/xcode/osx/../../src/hosts/FolderWatcher-mac.mm:177: warning: 'void FWStartWatcherThread()' defined but not used
