SDK 1.4p0 breaking changes
Postby DeepFreezZA » Thu Mar 07, 2013 2:16 pm
Just thought I would start a place to list some of the breaking changes from 1.3 to 1.4.
  1. MOAIGfxDevice.setClearColor(0,0,0,1)
no longer works as per some examples
With a bit of syntax mangling the following does work
  1. MOAIGfxDevice.getFrameBuffer():setClearColor(0,0,0,1)
DeepFreezZA
Re: SDK 1.4p0 breaking changes
Postby franciscotufro » Thu Mar 07, 2013 6:32 pm
Great initiative! Thanks a lot!
franciscotufro
Postby ibisum » Thu Mar 07, 2013 7:59 pm
This sort of breaking of things is a bit of a nonsense! Can we also ask why such things get borked in this thread?
Postby DeepFreezZA » Fri Mar 08, 2013 5:32 am
Lets stick to the issues and fixes here and move the debate about why to another thread, just to keep things easy to find.
DeepFreezZA
Postby ezraanderson » Wed Apr 03, 2013 10:13 pm
vs2010
problem with loading a texture
  1.
  2. --local texture =   MOAIImageTexture.new() --can't load a texture with this, worked on 1.3
  3. local texture =         MOAITexture.new()             --this seams to work fine
  4.
problem with scaling a layer
  1.
  2. layer:setScl(1.2,1.3) --doesn't do anything, worked fine on 1.3
  3.
So i had a chance to try a 1.4, had some problems.
Does anybody know why i can't scale the layer anymore with setScl, i don't want to use fitters or cameras.
edit: i fixed it by using viewport:setScale(width,height) when a window resizes
ezraanderson
Postby ezraanderson » Thu Apr 04, 2013 11:59 am
this is another one, MOAIRenderMgr.grabNextFrame ( img, write_Image )
image-framebuffer-grab-sample-not-working-t1748/
ezraanderson
Postby spectralcanine » Thu Apr 04, 2013 12:26 pm
ezraanderson wrote:problem with scaling a layer
  1.
  3.
You can't rotate or move them either.
This has been fixed already, but nobody's making nightly builds.
You can test this by grabbing an updated (or compiling your own) library from here
spectralcanine
Users browsing this forum: Google [Bot] and 1 guest
